17155
17155
    DESCO
    GNDHLDSPSBLEHIVIS100PK
17155 数据手册
Yellow Polyester Material Black Conductive Strip 1/2" 12" Description: Desco’s disposable heel grounder provides a path-to-ground and does not generate a charge when used with an ESD floor. The highly visible yellow polyester fabric identifies wearers as properly grounded. The material is non-marring and will not mark floors. The disposable heel grounder is designed for single use and should be removed and disposed of after use. Installation: 1. Insert the non-adhesive end of the heel grounder inside the shoe so that the black dot is in the center of the heel area. 2. Wrap the heel grounder around the back (or side) of shoe so that the adhesive can be adhered to the bottom of the heel. 3. Remove perforated section by lifting the paper backing from the middle as shown. 4. Press adhesive part of the foot grounder to the heel of the shoe. Do not allow adhesive to come in contact with any part of the shoe except for the heel. The adhesive may leave a residue. 5. Step in to shoe. Disposable heel grounder is to be installed on both shoes and used with ESD flooring. 6. Test each worn foot grounder with a Personal Grounding Tester Remove perforated section here and begin peeling towards the left Electrical Properties: Dimensions: 1/2" x 12" Resistance to Ground (Rtg): ≥ 5 x 104 < 8 x 105 ohms ITEM  17155 DESCRIPTION Disposable Heel Grounder LENGTH 12" PKG. 100 Unless otherwise noted, tolerance ± 10% Made in the United Kingdom Specifications and procedures subject to change without notice. Bottom Heel of Shoe Heel Grounder, High Visibility, Disposable DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 © 2014 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 17155 DATE: September 2014
17155 价格&库存
很抱歉,暂时无法提供与“17155”相匹配的价格&库存,您可以联系我们找货
