09680
09680
    DESCO
    CORDESDECON12'COILED4MMSNAP
09680 数据手册
NON-RESISTOR END RESISTOR END A. Patented* barrel type banana plug with machined contour spring support. Crimped uniformly from 4 sides for maximum strength. Fits industry standard banana jack ≥ .157". Will maintain greater than 1 pound disengagement force over the life of the cord. E. Autosplice brass crimp secures conductors to resistor lead and provides stress relief for resistor. B. Thermoplastic elastomer strain relief molded on. Bending Life Test average >1,000,000 cycles per ANSI/ESD S20.20 (Tested per ESD S1.1). Break load average 30 pounds. G. Spring loaded 4mm medical snap socket. Spring separation .125" - .165". Provides 1-5 pound breakaway from .160" snap stud (ESD S1.1). Compatible with most major brands. C. Relaxed retraction coil cord produces less tug force on wearer’s wrist. Wire insulation black color PVC. Break load average 30 pounds. H. Desco logo molded in compliance with ANSI/ESD S1.1. D. Single T-2940 tinsel conductor. Consisting of 7 strands of polyester wrapped with copper. High flex life. Equivalent is 29 gauge (cir mil and/or ohms). J. Underwriters Laboratory Listing 90P1C when used with Desco 09025, 09026, 09027, 09028, 09041, 09043, 09044, 09045, and 14840 wristbands. F. One megohm ±5%, 1/4 watt, series resistor limits current for operator safety. I. Date coded with date of manufacture. Meets required limits of ANSI/ESD S20.20 and requirements of ANSI/ESD S1.1 Made in the United States ofAmerica ITEM 09480 09680 09682 Retracted Length X 12" 24" 30" Y 20" 32" 38" Extended Length Nominal 6' 12' 15' Max 8.5' 17' 22' Unless otherwise noted, tolerance ±10% Specifications and procedures subject to change without notice. GROUND CORD, WRIST STRAP, RELAXED RETRACTION, COILED DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 ® 2012 DESCO INDUSTRIES INC. Employee Owned *U.S. Patent 5951337 DRAWING NUMBER 09480 DATE: April 2012
09680 价格&库存
很抱歉,暂时无法提供与“09680”相匹配的价格&库存,您可以联系我们找货
