Description:
SPI’s BRD Series Three Layer Vinyl provides an effective ESD work surface
where working on ESD sensitive items. Durable with heavy vinyl surface, and buried
conductive layer. Matting is easily grounded with the use of a Common Point Ground
Cord. Smooth top benefits easy to clean. All mats are easily maintained and should be
regularly cleaned using SPI's Resque 2 Worksurface Cleaner.
Specifications:
Resistance Top to Top (RTT):
10E7 - 10E8 Ohms, per S20.20 ESD STM S4.1
Resistance Top to Ground point (RTG): 10E6 - 10E8 Ohms, per S20.20 ESD STM S4.1
Thickness:
0.125" tolerance ± .010"
Colors:
Blue, Gray
Standards:
• Meets the requirements of ANSI/ESD S20.20, and
recommendation of ESDSTM S4.1, EIA 625, MILHDBK -263 and MIL-STD-1686.
Disclaimer:
All statements, technical data, and recommendations contained herein are based upon tests we believe to be reliable.
However, the accuracy or completeness thereof is not guaranteed. The proper and correct applications of products
and data is the responsibility of the user. Statements or recommendations not contained herein shall have no force or
effect unless embodied in a written agreement signed by authorized offers of Desco Industries, Inc.
Features:
• Compatible with constant monitors
• Good electrical performance
See reverse side for available
mat and roll sizes.
BRD Series Dissipative Three-Layer Vinyl
ESD SYSTEMS.COM
432 NORTHBORO ROAD CENTRAL
MARLBORO, MA 01752 USA
TEL. (508) 485-7390 FAX (508) 480-0257
© 2008 DESCO INDUSTRIES INC.
Employee Owned
Visit our online
library of Tech Drawings:
ESDSystems.com
DRAWING NUMBER
BRD Series
DATE:
December
2008
Item Number Reference For BRD Series Dissipative Three-Layer Vinyl
ROLL STOCK
KITS
MAT TOP KIT INCLUDES
One installed 10mm snap socket
BRD Series
Is Also
Available In
Full
Rolls
Mat Top Kit Item Numbers
SIZE
BLUE
GRAY
18" x 24"
96104
96105
18" x 36"
96108
96109
18" x 48"
96112
96113
24" x 24"
96116
96117
24" x 36"
96120
96121
24" x 48"
96124
96125
24" x 60"
96128
96129
SIZE
BLUE
GRAY
24" x 72"
96130
96131
24" x 50'
96100
96101
24" x 84"
96132
96133
24" x 96"
96134
96135
24" x 100'
96102
96103
30" x 36"
96136
96137
30" x 50'
96106
96107
30" x 48"
96138
96139
30" x 100'
96110
96111
30” x 60”
96140
96141
36" x 50'
96114
96115
30” x 72”
96142
96143
30” x 84”
96144
96145
36" x 100'
96118
96119
30” x 96”
96146
96147
48" x 50'
96122
96123
36" x 36"
96148
96149
48" x 100'
96126
96127
36" x 48"
96150
96151
36" x 60"
96152
96153
36" x 72"
96154
96155
36" x 84"
96156
96157
36" x 96"
96158
96159
48" x 48"
96160
96161
48" x 60"
96162
96163
48" x 72"
96164
96165
48" x 84"
96166
96167
48" x 96"
96168
96169
Employee Owned
Roll Stock Item Numbers
Hardware is not included with rolls.
For best results use 95329
Common Point Ground Cord
with BRD Series Dissipative
Three-Layer Rubber
Grounding Intervals for ESD Mats
Sufficient ground cords should be used to reliably meet ANSI/ESD S20.20 Table 1 less than 1 x 10E9
ohms for worksurfaces. An industry recommendation has been that continuous runs of ESD matting should
be grounded at ten foot intervals to allow proper charge decay rates with each individual ESD mat should
be grounded with ground snaplocated no further than five feet from either end.
Matting materials have a tendency to shrink slightly when first unrolled. In applications where length is
critical, allow the material to relax for at least 4 hours before cutting to size. Always trim with a sharp
knife or razor blade.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Desco:
95329
很抱歉,暂时无法提供与“95329”相匹配的价格&库存,您可以联系我们找货
