AS03608MR-4-R
36mm Speaker
3541 Stop Eight Road • Dayton, Ohio 45414
Product Overview
• 36mm diameter speaker with Neodymium magnet for 85 dB sensivity
• 0.5W connuous, 1W maximum power handling and 8Ω impedance
• Mylar cone for linear frequency response and moisture resistance
• Less than 5mm (1/4”) thick for space-limited applicaons
Frequency Response (1W @ 0.5 meter)
PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 12/15.
AS03608MR-4-R
36mm Speaker
Mechanical and Environment Testing
Test Description
Test Condition
High Temperature
60°C with random humidity for 96 hours
Low Temperature
-30°C with random humidity for 96 hours
40°C with 90% to 95% relative humidity for 96
hours
Humidity
Frequency Response Measurement Setup
Power Test
1W white noise signal for 96 hours
Drop Test
75 cm free fall onto 5 mm thick board, 10 cycles
Temperature Cycle Test
-25°C to 60°C, five 60 minute cycles
After tests, speaker shall rest for 1 hours. SPL shall not deviate ±3 dB from pre-test measurement.
SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
OUTPUT SPL @ 1W/0.5M
(AT 0.6, 0.8, 1.0, 1.2 kHz)
DISTORTION (MAX.)
RESONANT FREQUENCY
FREQUENCY RANGE
HOUSING MATERIAL
CONE MATERIAL
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
VALUES
UNITS
0.8
1
8 ± 15%
W
W
OHM
85 ± 3
dBA
5%
450 ± 20%
450 ~ 20,000
METAL
MYLAR
N35
-20 ~ +50
8.5
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
©2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
A
B
C
DESCRIPTION
DATE
APPROVED
RELEASED FROM ENGINEERING
REVISED HEIGHT DIMENSION
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED OUTPUT SPL DISTANCE kHz
5/10/2006
3/16/2007
12/3/2008
11/11/2011
R.W.
B.R.
M.L.
Hz
Hz
4.3 0.3
°C
grams
36 0.2
1.8 0.2
15.3 0.2
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE ±0.5 AND
ANGLES ARE ±3°.
SIZE
A3
AS03608MR-4-R.idw
Designed by
Date
Checked by
Date
Approved by
J.D.
5/10/2006
E.P.
5/10/2006
B.R.
Date
Drawn Date
5/10/2006 12/3/2008
AS03608MR-4-R
Speaker
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AS03608MR-4-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.132231+4.43190
- 10+26.0119610+3.37753
- 25+23.4663325+3.04699
- 50+21.7443650+2.82340
- 100+20.17524100+2.61966
- 250+18.31071250+2.37756
- 500+17.04056500+2.21264
- 1000+15.878281000+2.06172
- 5000+14.994915000+1.94702
