AS02008MR-5-R
AS02008MR-5-R
    PUIAUDIO
    SPEAKER 8 OHM .5W 86DB 20MM
AS02008MR-5-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2021, PUI Audio Inc. Data Sheet AS02008MR-5-R Specifications Parameters Rated Input Power Max Input Power Impedance Output SPL @ 0.1W/0.1m (AVG. 0.8, 1.0, 1.2, 1.5 kHz) Resonant Frequency Frequency Range THD max. (1kHz, 0.5W) Frame Material Diaphragm Material Magnet Material Weight Ingress Protection Rating Acceptable Soldering Methods Buzz, Rattle, etc. Environmental Compliances Polarity Storage Temperature Operating Temperature Values 0.5 0.8 8 ± 15% Units Watts Watts Ohms 87 ± 3 630 ± 20% Fo – 10,000 10% Metal PET NdFeB 2.4 NA dB Hz Hz - Hand Solder Should not be audible at 2.0V sine wave between (Fo-10kHz) ROHS/REACH Diaphragm to move in forward direction when +pos applied to pos+ terminal -30 to 60 -25 to 55 Measurement Method www.puiaudio.com Grams 350C iron temp, solder time 3 seconds per terminal or less - °C °C This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2021, PUI Audio Inc. Typical Frequency Response (0.1W, 0.1m) Impedance Curve (0.1W, 0.1m) www.puiaudio.com This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2021, PUI Audio Inc. Reliability Testing Type of Test Test Specifications Keep 96 hours at +60℃±3℃ and leave 3 hours in normal temperature and then check Keep 96 hours at -30℃±3℃ and leave 3 hours in normal temperature and then check Keep 96 hours at + 40℃±3℃ relative humidity 95% and leave 3 hours in normal temperature and then checked. High Temperature Test Low Temperature Test Humidity Test Low temperature: -30℃±3℃, temperature:+60℃±3℃, cycle: 1 hour/cycle each, and then keep 5 cycles in a room. 10~55~10Hz sin-wave sweep 15min. 5G(constant) Vibration Test X,Y, Z 3 direction. 2 hours each, total 6 hours. Free drop one piece from 100cm height to 20mm thick wooden board. X,Y,Z each direction, 6 times. Drop Test Load Test Rated Power white noise is applied for 96 hours Capable of withstand 1kg load for 15seconds without resulting in any damage or rejection. Terminal Strength Test Max Power Test Max power 1 min on – 2 min off 10 cycles. After tests, part shall be within ±3dB. Temperature Cycle Testing Dimensions DOUBLE SIDED ADHESIVE FOAM BLACK NET PUI YM AS02008MR -5-R BLACK GLUE PUI YM AS02008MR -5-R Y M ---日期代码 MONTH YEAR 注:日期代码将随年月变化 如:1.6G---代表06年7月 2.7F---代表07年6月 www.puiaudio.com This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2021, PUI Audio Inc. Packaging × × × Revision A B C Note: 1. 2. Specifications Revisions Description Released from Engineering Revised Terminal Layout Revised to 3D Template Revised Resonant Frequency/Range, SPL, Dimensions Unless otherwise specified: A. All dimensions are in millimeters. B. Default tolerances are ±0.5mm and angles are ±3°. Specifications subject to change or withdrawal without notice. www.puiaudio.com Date 4/28/2009 9/24/2010 7/18/2013 1/24/2022
AS02008MR-5-R 价格&库存
很抱歉,暂时无法提供与“AS02008MR-5-R”相匹配的价格&库存,您可以联系我们找货
