AS01808MR-R
AS01808MR-R
    PUIAUDIO
    SPEAKER 8OHM 1W TOP PORT 80DB
AS01808MR-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 0.8, 1.0, 1.2, 1.5 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT 18 VALUES UNITS 1 1.5 8 15% W W OHM 80 3 5% 650 20% Fo ~ 18,000 ABS MYLAR RARE EARTH -25 ~ +60 2.8 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E RELEASED FROM ENGINEERING ADDED RoHS NOTE REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED RESONANT FREQUENCY REVISED OVERALL HEIGHT TOLERANCE ADJUSTMENT TO RESONANT FREQUENCY AND RANGE 12/7/2005 11/4/2008 11/4/2008 8/25/2017 4/20/2020 5/13/2020 J.D. B.R. M.V. M.L. M.L. 2003, Projects Unlimited Inc. dBA Hz Hz C grams 0.2 5.8 0.5 5 0.2 BLUE MARK (+) LEAD 13.2 1 0.2 0.2 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2015/863/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS01808MR-R.idw Designed by Date Checked by Date Approved by J.D. 12/31/2007 X.X. 7/18/2007 X.X. Date Drawn Date 7/18/2007 11/4/2008 AS01808MR-R Speaker Edition Sheet - 1/1
AS01808MR-R 价格&库存
很抱歉,暂时无法提供与“AS01808MR-R”相匹配的价格&库存,您可以联系我们找货
AS01808MR-R
  • 1+41.773891+5.41118
  • 10+31.8778310+4.12930
  • 25+28.7736825+3.72720
  • 50+26.6697150+3.45466
  • 100+24.75298100+3.20638
  • 250+22.47446250+2.91123
  • 500+20.92203500+2.71014
  • 1000+19.500661000+2.52602
  • 5000+18.725495000+2.42561
库存:8521
