ASE02008MR-LW150-R
20mm Enclosed Speaker
3541 Stop Eight Road • Dayton, Ohio 45414
Product Overview
• 20mm square speaker with 150mm lead wires for instant integra on
• 0.5W con nuous, 0.7W maximum power handling and 8Ω impedance
• Rugged ABS enclosure designed for op mum sound
Frequency Response (0.5W @ 0.5 meters)
PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15.
ASE02008MR-LW150-R
Mechanical and Environment Testing
Temperature Cycle Test Graph
Test Description
Test Condition
High Temperature
60°C ±2°C with random humidity for 96 hours
Low Temperature
-25°C ±2°C with random humidity for 96 hours
Humidity
40°C with 90% to 95% relative humidity for 96
hours
Vibration
1.5 mm movement modulated at 10 to 55 Hz for 2
hours
Drop Test
75 cm free fall onto concrete floor, 10 cycles
-25°C to 60°C, 4 cycles (refer to Temperature Cycle
Test Graph)
After tests, speaker shall rest for 1 hours. SPL shall not deviate ±4 dB from pre-test measurement.
Frequency Response and SPL Measurement Setup
Speaker Parameters
Specification
ASE2008MR-R
Fo (Hz)
1400
Frequency Range
800~20,000
Impedance (ohm)
8
SPL (dB) @ 0.5W/0.5m
79
SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
OUTPUT SPL @ 0.5W/0.5M
(AT 1.4, 1.6, 2.0, 2.5 kHz)
DISTORTION (MAX.)
RESONANT FREQUENCY
FREQUENCY RANGE
HOUSING MATERIAL
CONE MATERIAL
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
VALUES
UNITS
0.5
0.7
8 15%
W
W
OHM
79 3
dBA
5%
1400 20%
800 ~ 20,000
ABS
MYLAR
RARE EARTH
-25 ~ +60
26
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
REVISION HISTORY
LTR
DESCRIPTION
DATE
RELEASED FROM ENGINEERING
1/23/2014
APPROVED
2003, Projects Unlimited Inc.
Hz
Hz
C
grams
20 B0.2
150 B5
3 B0.2
UL3302 AWG28
20 B0.2
2 B1
1.5
1.5
5 B0.3
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3.
SIZE
A3
ASE02008MR-LW150-R.idw
Designed by
Date
Checked by
Date
Approved by
Date
Drawn Date
J.D.
1/6/2014
M.L.
1/6/2014
B.R.
1/6/2014
1/6/2014
ASE02008MR-LW150-R
Speaker
Edition
Sheet
1/1
很抱歉,暂时无法提供与“ASE02008MR-LW150-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+41.820871+5.40930
- 10+31.9226310+4.12901
- 25+28.8200625+3.72771
- 80+25.3977480+3.28506
- 160+23.59647160+3.05207
- 320+21.95159320+2.83932
- 560+20.72632560+2.68084
- 1040+19.468651040+2.51816
