AST-01508MR-R
AST-01508MR-R
    PUIAUDIO
    SPEAKER 8OHM 300MW TOP PORT 87DB
AST-01508MR-R 数据手册
  AST-01508MR-R 15mm Speaker 3541 Stop Eight Road • Dayton, Ohio 45414 Product Overview  • 15mm diameter speaker with Neodymium magnet for 87 dB sensi vity • 0.3W con nuous, 0.5W maximum power handling and 8Ω impedance • Mylar cone for wide frequency response • Thru hole design and wave solderable for PCB mount Frequency Response (0.3W @ 0.1 meter) PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15.   AST-01508MR-R 15mm Speaker Mechanical and Environment Testing Test Description Test Condition High Temperature 55°C with random humidity for 96 hours Packaging Information Low Temperature -20°C with random humidity for 96 hours 40°C with 90% to 95% relative humidity for 96 Humidity hours 1.5 mm movement modulated at 10 to 55 Hz for Vibration 2 hours 75 cm free fall onto 40 mm thick board, 10 cyDrop Test cles -20°C to 55°C, 5 cycles (refer to Temperature Temperature Cycle Test Cycle Test Graph) After tests, speaker shall rest for 1 hours. SPL shall not deviate ±3 dB from pre-test measurement. Temperature Cycle Test Graph Wave Solder Profile PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15. SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 0.3W/0.1M (AT 2.0, 2.5, 3.0, 4.0 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 0.3 0.5 8 ± 15% W W OHM 87 ± 3 dBA 5% 1,700 ± 20% 1,700 ~ 20,000 PBT+20% GLASS MYLAR Nd-Fe-B -20 ~ +55 1.83 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E RELEASED FROM ENGINEERING ADDED OVERALL HEIGHT DIMENSION REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED WEIGHT OF PART REVISED HOUSING MATERIAL REVISED HOUSING MATERIAL 12/31/2007 2/23/2009 2/24/2009 6/8/2010 7/27/2010 3/1/2017 B.R. B.R. B.R. B.R. M.V. ©2003, Projects Unlimited Inc. Hz Hz - 13.65 °C grams 7.5 n15 n0.8 `0.05 (2) 7.6 5.8 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE ±0.5 AND ANGLES ARE ±3°. SIZE A3 AST-01508MR-R.idw Designed by Date Checked by Date Approved by J.A.F. 12/8/2005 B.R. 12/8/2005 E.P. Date Drawn Date 12/8/2005 2/24/2009 AST-01508MR-R Speaker Edition Sheet - 1/1
AST-01508MR-R 价格&库存
很抱歉,暂时无法提供与“AST-01508MR-R”相匹配的价格&库存,您可以联系我们找货
AST-01508MR-R
    • 1+30.29386
    • 10+27.24260
    • 100+25.13901
    • 500+23.34783
    • 1000+18.93236
    库存:394
    AST-01508MR-R
    • 1+40.544951+5.24890
    • 10+30.9587810+4.00789
    • 25+27.9431225+3.61748
    • 50+25.9011350+3.35313
    • 100+24.04179100+3.11242
    • 400+20.79422400+2.69200
    • 800+19.37525800+2.50830
    • 1200+18.601061200+2.40807
    库存:16664
