AS04008PR-WR-R
AS04008PR-WR-R
    PUIAUDIO
    8 Ohm Magnetic Speaker 500mW 700Hz ~ 4.75kHz Top Round 92dB
AS04008PR-WR-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 0.5W/0.1M (AT 0.8, 1.0, 1.2, 1.5, kHZ) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 0.5 0.8 8 15% W W OHM 94 3 5% 700 20% 700 ~ 4,800 METAL TREATED PAPER Nd-Fe-B -20 ~ +60 9 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B c RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADDED NOTE 5 REVISED SPL, DIMENSIONS, AND ROHS STATUS 9/25/2006 10/21/2008 8/12/2011 9/26/2013 B.R. B.R. R.W. 2003, Projects Unlimited Inc. dBA Hz Hz C grams 40 6.5 0.3 3.95 0.3 1.9 0.2 13.9 0.2 0.2 4 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. CONE HAS BEEN TREATED FOR WATER RESISTANCE. 5. BASE SPEAKER PUI# AS04008PR-R. 36.1 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS04008PR-WR-R.idw Designed by Date Checked by Date Approved by J.D. 9/25/2006 B.R. 9/25/2006 R.W. Date Drawn Date 9/25/2006 10/21/2008 AS04008PR-WR-R Speaker Edition Sheet - 1/1
AS04008PR-WR-R 价格&库存
很抱歉,暂时无法提供与“AS04008PR-WR-R”相匹配的价格&库存,您可以联系我们找货
