AST-01532MR-R
AST-01532MR-R
    PUIAUDIO
    SPEAKR 32OHM 300MW TOP PORT 87DB
AST-01532MR-R 数据手册
  AST-01532MR-R 15mm Speaker 3541 Stop Eight Road • Dayton, Ohio 45414 Product Overview  • 15mm diameter speaker with Neodymium magnet for 87 dB sensi vity • 0.3W con nuous, 0.5W maximum power handling and 32Ω impedance • Mylar cone for wide frequency response • Thru hole design and wave solderable for PCB mount Frequency Response (0.3W @ 0.1 meter) PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15.   AST-01532MR-R 15mm Speaker Mechanical and Environment Testing Test Description Test Condition High Temperature 55°C with random humidity for 96 hours Low Temperature -20°C with random humidity for 96 hours 40°C with 90% to 95% relative humidity for 96 hours 1.5 mm movement modulated at 10 to 55 Hz for 2 hours Humidity Vibration Drop Test Packaging Information 75 cm free fall onto 40 mm thick board, 10 cy- -20°C to 55°C, 5 cycles (refer to Temperature Cycle Test Graph) After tests, speaker shall rest for 1 hours. SPL shall not deviate ±3 dB from pre-test measurement. Temperature Cycle Test Temperature Cycle Test Graph Wave Solder Profile PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15. SPECIFICATIONS PARAMETERS VALUES UNITS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 0.3W/0.1M (AT 2.0, 2.5, 3.0, 4.0 kHz) DISTORTION (MAX.) 0.3 0.5 32 ± 15% W W OHM 87 ± 3 dBA RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT 10% 2,100 ± 20% 2,100 ~ 20,000 PBT MYLAR Nd-Fe-B -20 ~ +55 2 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR A ©2003, Projects Unlimited Inc. DESCRIPTION DATE APPROVED RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE 5/9/2006 6/26/2008 B.R. Hz Hz °C grams 7.5 5.8 15 7.6 0.8 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE ±0.5 AND ANGLES ARE ±3°. SIZE A3 AST-01532MR-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 5/8/2006 E.P. 5/8/2006 B.R. 5/8/2006 6/26/2008 AST-01532MR-R Speaker Edition Sheet - 1/1
AST-01532MR-R 价格&库存
很抱歉,暂时无法提供与“AST-01532MR-R”相匹配的价格&库存,您可以联系我们找货
AST-01532MR-R
  • 1+47.606771+5.70709
  • 10+36.4330310+4.36758
  • 25+32.9016525+3.94424
  • 50+30.5030450+3.65670
  • 100+28.31839100+3.39480
  • 400+24.50267400+2.93738
  • 800+22.83475800+2.73743
  • 1200+21.924571200+2.62831
库存:446
