AS06608MR-R
AS06608MR-R
    PUIAUDIO
    SPEAKER 8OHM 500MW TOP PORT 84DB
AS06608MR-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/1M (AT 1.0, 1.2, 1.5, 2.0 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 0.5 1.0 8 W W OHM 84 3 5% 380 20% 380 ~ 7,500 METAL MYLAR FERRITE -20~ +60 18 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED OUTPUT SPL DISTANCE REVISED TO INVENTOR 3-D DRAWING TEMPLATE UPDATE SPEC AND DIMENSIONS 8/11/2005 11/10/2006 6/20/2008 11/1/2013 D.F. B.R. M.L. 2003, Projects Unlimited Inc. dBA Hz Hz - 12.5 C grams 2.2 0.3 66 17 0.3 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS06608MR-R.idw Designed by Date Checked by Date Approved by J.A.F. 8/10/2005 E.P. 8/10/2005 B.R. Date Drawn Date 8/10/2005 6/20/2008 AS06608MR-R Speaker Edition Sheet - 1/1
AS06608MR-R 价格&库存
很抱歉,暂时无法提供与“AS06608MR-R”相匹配的价格&库存,您可以联系我们找货
AS06608MR-R
  • 1+46.343291+5.99574
  • 10+35.4736410+4.58947
  • 25+32.0368525+4.14483
  • 50+29.7064550+3.84333
  • 100+27.58290100+3.56859
  • 250+25.05530250+3.24158
  • 500+23.33236500+3.01867
  • 1000+21.754801000+2.81457
库存:373
