AST-01708MR-R
17mm Speaker
3541 Stop Eight Road • Dayton, Ohio 45414
Product Overview
• 17mm diameter speaker with Neodymium magnet for 90 dB sensi vity
• 0.2W con nuous, 0.5W maximum power handling and 8Ω impedance
• Mylar cone for wide frequency response
• Thru hole design and wave solderable for PCB mount
Frequency Response (0.2W @ 0.1 meter)
PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15.
AST-01708MR-R
17mm Speaker
Mechanical and Environment Testing
Test Description
Test Condition
High Temperature
55°C with random humidity for 96 hours
Low Temperature
-20°C with random humidity for 96 hours
40°C with 90% to 95% relative humidity for 96
hours
1.5 mm movement modulated at 10 to 55 Hz for
2 hours
Humidity
Vibration
Drop Test
Packaging Information
75 cm free fall onto 40 mm thick board, 10 cy-
-20°C to 55°C, 5 cycles (refer to Temperature
Cycle Test Graph)
After tests, speaker shall rest for 1 hours. SPL shall not deviate ±3 dB from pre-test measurement.
Temperature Cycle Test
Temperature Cycle Test Graph
Wave Solder Profile
SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
OUTPUT SPL @ 0.2W/0.1M
(AT 2.0, 2.5, 3.0, 4.0 kHz)
DISTORTION (MAX.)
RESONANT FREQUENCY
FREQUENCY RANGE
HOUSING MATERIAL
CONE MATERIAL
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
VALUES
UNITS
0.2
0.5
8 ± 15%
W
W
OHM
87 ± 3
dBA
5%
1,500 ± 20%
1,500 ~ 20,000
PBT
MYLAR
Nd-Fe-B
-20 ~ +55
2
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
©2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
A
B
DATE
RELEASED FROM ENGINEERING
ADDED OVERALL HEIGHT DIMENSION
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
11/2/2005
2/24/2009
2/25/2009
APPROVED
B.R.
B.R.
Hz
Hz
°C
grams
14.35
8
n17
5.8
7.6
n0.8 `0.05 (2)
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE ±0.5 AND
ANGLES ARE ±3°.
SIZE
A3
AST-01708MR-R.idw
Designed by
Date
Checked by
Date
Approved by
J.A.F.
11/2/2005
B.R.
11/2/2005
E.P.
Date
Drawn Date
11/2/2005 2/25/2009
AST-01708MR-R
Speaker
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AST-01708MR-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+44.212111+5.73793
- 10+33.8340610+4.39105
- 25+30.5551325+3.96550
- 50+28.3277750+3.67643
- 100+26.29890100+3.41312
- 250+23.88637250+3.10002
- 650+21.65615650+2.81058
- 1300+20.199231300+2.62149
