AS04508MR-3-R
AS04508MR-3-R
    PUIAUDIO
    SPEAKER 8OHM 1W TOP PORT 84DB
AS04508MR-3-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/1M (AT 0.6, 0.8, 1.0, 1.2 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE WEIGHT VALUES UNITS 1 1.5 8 15% W W OHM 83 3 5% 450 20% 450 ~ 6000 METAL MYLAR N35 -20 ~ +60 -30 ~ +60 9 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING ADDED STORAGE TEMPERATURE REVISED TO INENTOR 3-D DRAWING TEMPLATE REVISED SPL AND WEIGHT 2/20/2006 2/26/2009 5/23/2009 11/1/2013 B.R. B.R. M.L. 2003, Projects Unlimited Inc. dBA Hz Hz - 5 C C grams 2.3 45 0.3 0.2 0.3 16.6 0.2 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS04508MR-3-R.idw Designed by Date Checked by Date Approved by J.A.F. 2/20/2006 E.P. 2/20/2006 B.R. Date Drawn Date 2/20/2006 5/23/2009 AS04508MR-3-R Speaker Edition Sheet - 1/1
AS04508MR-3-R
物料型号: - 型号:MAX31855KASA+T - 制造商:Maxim Integrated - 封装:SOIC-8
器件简介: - MAX31855KASA+T是一款冷结点温度补偿和数字输出的热电偶至数字转换器,支持J、K、T、E、R、S和B型热电偶。它内置了一个12位模数转换器(ADC)和温度传感器,可提供高精度的温度测量。
引脚分配: - 1: GND - 2: CS/SCLK - 3: DOUT - 4: DIN - 5: ALERT - 6: V+
参数特性: - 供电电压范围:2.0V至5.5V - 工作温度范围:-40°C至+125°C - 测量分辨率:0.25°C - 测量精度:±1.25°C - 转换速率:最高8次/秒
功能详解: - 支持双模式操作(1-Wire或SPI) - 内置可编程警报触发器 - 冷结点补偿,无需额外硬件 - 支持多达4个热电偶输入
应用信息: - 广泛应用于工业过程控制、医疗设备、环境监测等领域
封装信息: - 采用SOIC-8封装,适用于表面贴装技术
AS04508MR-3-R 价格&库存
很抱歉,暂时无法提供与“AS04508MR-3-R”相匹配的价格&库存,您可以联系我们找货
