SMS-1308MS-2-R
SMS-1308MS-2-R
    PUIAUDIO
    SPEAKER 8OHM .7W 88DB 13MM SMD
SMS-1308MS-2-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 0.7W/0.1M (AT 1.0, 1.6, 2.0, 3.2 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 0.7 1 8 15% W W OHM 88 3 5% 1100 20% Fo ~ 20,000 LCP KAPTON SmCo -40 ~ +85 1.2 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED FREQUENCY RANGE REVISED RESONANT FREQUENCY REVISED LOW OPERATING TEMPERATURE FROM -30C TO -40C 8/9/2011 4/27/2012 6/15/2017 4/3/2019 B.R. M.L. M.V. dBA Hz Hz C grams 13 12 DUMMY LEADS 1.7 1.5 1 (4) 2.2 (4) 13 2.4 (2) 6.5 LEAD (-) LEAD (+) 4 1 10.4 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 SMS-1308MS-2-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 8/9/2011 M.L. 8/10/2011 B.R. 8/10/2011 8/9/2011 SMS-1308MS-2-R Speaker Edition Sheet - 1/1
SMS-1308MS-2-R 价格&库存
很抱歉,暂时无法提供与“SMS-1308MS-2-R”相匹配的价格&库存,您可以联系我们找货
SMS-1308MS-2-R
    • 1+58.90067
    • 10+53.05850
    • 100+48.93462
    • 500+45.36268
    • 1000+36.82333
    库存:394
    SMS-1308MS-2-R
    • 1+66.99490
    • 10+52.94880
    • 25+49.58540
    • 50+45.82420
    库存:1200
    SMS-1308MS-2-R
    • 600+38.54840600+5.01117
    • 1200+38.036841200+4.94467
    库存:4154
    SMS-1308MS-2-R
    • 1+68.528011+8.90842
    • 10+54.0502010+7.02636
    • 25+49.3047625+6.40946
    • 50+46.5561750+6.05216
    库存:4154
