ASE03008MR-LW150-R
ASE03008MR-LW150-R
    PUIAUDIO
    SPEAKER ENCLOSURE 1 W 8 OHM 83 D
ASE03008MR-LW150-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 0.8, 1.0, 1.2, 1.5 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT 150 VALUES UNITS 1 1.5 8 15% W W OHM 83 3 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING UPDATED TEMPERATURE SPECIFICATIONS 1/23/2014 10/20/2017 M.V. 2003, Projects Unlimited Inc. dBA 5% 800 20% 550 ~ 18,000 ABS MYLAR RARE EARTH -40 ~ +85 72 Hz Hz C grams 5 30 0.2 25 0.2 R2.5 X2 6 0.3 R2.25 X2 4 UL3302 AWG28 20 0.2 25 2 0.2 1 R2.5 X2 5 5 5 0.2 0.2 2.2 0.2 X2 2.5 1 0.1 1 1 5 0.1 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 ASE03008MR-LW150-R.idw Designed by Date Checked by Date Approved by J.D. 1/16/2014 M.L. 1/16/2014 B.R. Date Drawn Date 1/16/2014 1/16/2014 ASE03008MR-LW150-R Speaker Edition Sheet - 1/1
ASE03008MR-LW150-R 价格&库存
很抱歉,暂时无法提供与“ASE03008MR-LW150-R”相匹配的价格&库存,您可以联系我们找货
