AS07104PO-WR-R
AS07104PO-WR-R
    PUIAUDIO
    SPEAKER 4OHM 3W 86DB 71X41MM
AS07104PO-WR-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 0.8, 1.0, 1.2, 1.5 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 3 5 4 15% W W OHM 86 3 5% 250 70% 100 ~ 20,000 METAL TREATED PAPER Nd-Fe-B -20 ~ +60 38 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADDED NOTE 5 REVISED SPL MEASUREMENT CORRECTED SPL DISTANCE 9/25/2006 6/19/2008 8/12/2011 6/7/2017 3/4/2021 R.W. B.R. M.L. M.L. 2003, Projects Unlimited Inc. dBA Hz Hz - 41 25 1 C grams 33.3 2.8 0.3 3.7 71 0.3 (4) 63 22 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. UNLESS OTHERWISE SPECIFIED: 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. 4. CONE HAS BEEN TREATED FOR WATER RESISTANCE. 5. BASE SPEAKER PUI# AS07104PO-R. DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS07104PO-WR-R.idw Designed by Date Checked by Date Approved by J.D. 9/25/2006 B.R. 9/25/2006 R.W. Date Drawn Date 9/25/2006 6/19/2008 AS07104PO-WR-R Speaker Edition Sheet - 1/1
AS07104PO-WR-R 价格&库存
很抱歉,暂时无法提供与“AS07104PO-WR-R”相匹配的价格&库存,您可以联系我们找货
