AS04008CO-R
AS04008CO-R
    PUIAUDIO
    8 Ohm Magnetic Speaker 2W 200Hz ~ 20kHz Top Oval, Rectangular Frame 83dB
AS04008CO-R 数据手册
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 0.8, 1.0, 1.2, 1.5 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 2 3 8 15% W W OHM 83 3 5% 500 20% 200 ~ 20,000 METAL CLOTH Nd-Fe-B -20 ~ +60 7.6 REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED POWER RATINGS, SPL & FREQ. REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED RESONANT FREQUENCY 2/21/2006 3/6/2006 12/22/2008 9/25/2012 E.P. B.R. B.R. 2003, Projects Unlimited Inc. dBA Hz Hz - 5.8 20 16 C grams 0.2 0.2 1.6 0.3 0.15 2 (4) 40 0.2 14.5 36 0.3 SPEAKER TERMINAL (-) 0.2 SPEAKER TERMINAL (+) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS04008CO-R.idw Designed by Date Checked by Date Approved by J.A.F. 2/21/2006 E.P. 2/21/2006 B.R. Date Drawn Date 2/21/2006 12/12/2008 AS04008CO-R Speaker Edition Sheet - 1/1
AS04008CO-R 价格&库存
很抱歉,暂时无法提供与“AS04008CO-R”相匹配的价格&库存,您可以联系我们找货
