ASE04508MR-LW150-R
ASE04508MR-LW150-R
    PUIAUDIO
    8 Ohm Magnetic Speaker 3W 250Hz ~ 12kHz Top Rectangular 82dB
ASE04508MR-LW150-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 0.8, 1.0, 1.2, 1.5 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 3 5 8 15% W W OHM 82 3 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING REVISED RESONANT FREQUENCY AND DIMENSIONS 1/23/2014 6/13/2017 M.L. 2003, Projects Unlimited Inc. dBA 5% 420 20% Fo ~ 12,000 ABS MYLAR RARE EARTH -25 ~ +60 27 Hz Hz C grams 20 8.3 2.4 150 5 UL3302 AWG28 53.8 0.3 45 2 17.6 1 0.3 36 3 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 ASE04508MR-LW150-R.idw Designed by Date Checked by Date Approved by J.D. 1/17/2014 M.L. 1/17/2014 B.R. Date Drawn Date 1/17/2014 1/17/2014 ASE04508MR-LW150-R Speaker Edition Sheet - 1/1
ASE04508MR-LW150-R 价格&库存
很抱歉,暂时无法提供与“ASE04508MR-LW150-R”相匹配的价格&库存,您可以联系我们找货
ASE04508MR-LW150-R
    • 1+63.75351
    • 10+57.32818
    • 100+52.91271
    • 500+49.12207
    • 1000+39.86417
    库存:15
