AR027150MR-2-R
AR027150MR-2-R
    PUIAUDIO
    RECEIVER.015W150OHM118DBA
AR027150MR-2-R 数据手册
SPECIFICATIONS PARAMETERS VALUES UNITS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ .001W using IEC 318 Coupler (AT 1.0 kHz) DISTORTION (MAX.) FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT .015 .030 150 15% W W OHM 118 3 5% 20 ~ 10,000 ABS MYLAR NdFeB -20 ~ +60 5.2 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE - RELEASED FROM ENGINEERING 10/21/2015 ALL PURCHASES ARE SUBJECT TO THE PUI AUDIO TERMS AND CONDITIONS SALE FOUND AT http://www.puiaudio.com/pdf/terms_condition .pdf (paper copy available upon request). dBA 2003, Projects Unlimited Inc. Hz C grams 3.8 26.8 APPROVED 0.2 0.3 18 8 0.3 0.3 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AR027150MR-2-R.idw Designed by Date Checked by Date Approved by J.D. 10/21/2015 B.R. 10/21/2015 R.W. Date Drawn Date 10/21/2015 10/21/2015 AR027150MR-2-R Receiver Edition Sheet - 1/1
AR027150MR-2-R 价格&库存
很抱歉,暂时无法提供与“AR027150MR-2-R”相匹配的价格&库存,您可以联系我们找货
AR027150MR-2-R
    • 1+19.56760
    • 10+17.56815
    • 100+16.19352
    • 500+15.03758
    • 1000+12.20502
    库存:41
