AS02008MR-R
AS02008MR-R
    PUIAUDIO
    8 Ohm Magnetic Speaker 500mW 500Hz ~ 4kHz Top Round 86dB
AS02008MR-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Data Sheet AS02008MR-R Made for modern electronic devices, PUI Audio’s AS02008MR-R is designed to be as thin as possible and recreate the human voice with good fidelity. Features: • IP65-rated face when properly installed • Only 3mm thick • 2.4g weight • Designed for clear voice response Speaker Specifications Parameters Rated Input Power Max Input Power Impedance Sensitivity @ 0.1W/0.1m (at 0.8, 1.0, 1.2, 1.5 kHz) Resonant Frequency Frequency Range (-10 dB) Frame Material Magnet Material Weight Ingress Protection Rating Acceptable Soldering Methods Buzz, Rattle, etc. Environmental Compliances Polarity Storage Temperature Operating Temperature Values 0.5 0.8 8 ± 15% Units Watts Watts Ohms 86 ± 3 500 ± 20% 350 ~ 20,000 Metal NdFeB 2.4 IP65 Hand Solder for ≤3 seconds Shall not be audible with 2Vrms sine wave from 500 Hz to 4 kHz RoHS Cone shall move forward when a positive voltage is applied to the positive terminal -30 ~ +70 -20 ~ +55 dB Hz Hz Grams - PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 °C °C This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Measurement Method (Measured with 2V input with speaker mounted on IEC baffle) Typical Frequency Response (2V input measured at 10cm, two samples) PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Reliability Testing Type of Test High Temperature Test Low Temperature Test Humidity Test Test Specifications 96 hours at 70°C 96 hours at -30°C 96 hours at +40°C with relative humidity at 96% The part shall be subjected to 12 cycles using the following procedure: Low temperature: -40℃±3℃ Temperature Cycle Testing High temperature: +80℃±3℃ Cycle: 2 hours at High, 5 minutes High to Low, 2 hours at Low, 5 minutes Low to High 10 to 55 to 10 Hz sine sweep, per minute @ 1.5mm amplitude Vibration Test 2 hours in each axis X, Y, and Z. Shock Test If applicable, describe conditions of test. Drop speaker from a height of 1m onto a 20mm Drop Test thick board 5 times 2Vrms white noise is applied to the speaker for 96 hours Load Test Call out how pass/fail conditions are determined after the reliability testing is complete Dimensions (Right solder pad on left image below is positive +) PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Revision A B Specifications Revisions Description Released from Engineering Revised to Inventor 3D Template Changed Plating on Speaker Frame Note: 1. Unless otherwise specified: A. All dimensions are in millimeters. B. Default tolerances are ±0.5mm and angles are ±3°. 2. Specifications subject to change or withdrawal without notice. PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 Date 5/2/2006 1/25/2008 3/21/2016
AS02008MR-R 价格&库存
很抱歉,暂时无法提供与“AS02008MR-R”相匹配的价格&库存,您可以联系我们找货
