SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
OUTPUT SPL @ 1W/50CM
(AT 0.8, 1.0, 1.2, 1.5 kHz)
DISTORTION (MAX.)
RESONANT FREQUENCY
FREQUENCY RANGE
HOUSING MATERIAL
CONE MATERIAL
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
VALUES
UNITS
0.5
1
8 15%
W
W
OHM
82
3
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
C
D
RELEASED FROM ENGINEERING
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED OPERATING TEMP AND DIMENSIONS
REVISED MAGNET DIAMETER TO 12.9mm
REVISED SPL RATING DISTANCE FROM 1M TO 50CM
11/8/2005
11/6/2008
11/1/2013
5/24/2016
8/18/2017
B.R.
M.L.
M.L.
M.V.
2003, Projects Unlimited Inc.
dBA
5%
650 20%
650 ~ 15,000
METAL
MYLR
Nd-Fe-B
-20 ~ +60
5.2
30
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
Hz
Hz
C
grams
0.2
12.9
_
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 20011/65/EU COMPLIANT.
4.8
0.3
2.2
0.2
0.2
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AS03008MR-R.idw
Designed by
Date
Checked by
Date
Approved by
J.A.F.
11/8/2005
B.R.
11/8/2005
E.P.
Date
Drawn Date
11/8/2005 11/6/2008
AS03008MR-R
Speaker
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AS03008MR-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.179611+4.42746
- 10+26.0480710+3.37414
- 25+23.4989125+3.04393
- 60+21.3458860+2.76504
- 120+19.81341120+2.56653
- 300+17.99030300+2.33038
- 540+16.92983540+2.19301
- 1020+15.868611020+2.05554
- 5040+15.015735040+1.94507
