AS05708MR-R
AS05708MR-R
    PUIAUDIO
    SPEAKER 8OHM .5W 90DB 57MM
AS05708MR-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 0.8, 1.0, 1.2, 1.5 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 0.5 1 8 ± 15% W W OHM 90 ± 3 dBA 5% 450 ± 20% 450 ~ 4,500 METAL MYLAR Nd-Fe-B -20 ~ +60 20 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED SPEAKER HEIGHT REVISED TO INVENTOR 3-D DRAWING TEMPLATE 11/9/2006 2/2/2010 6/20/2010 B.R. B.R. ©2003, Projects Unlimited Inc. Hz Hz °C grams 14 2.7 B0.2 P57 P19.2 Ø51.8±0.3 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE ±0.5 AND ANGLES ARE ±3°. SIZE A3 AS05708MR-R.idw Designed by Date Checked by Date Approved by J.D. 11/8/2006 D.F. 11/8/2006 R.W. Date Drawn Date 11/8/2006 6/20/2010 AS05708MR-R Speaker Edition Sheet - 1/1
AS05708MR-R 价格&库存
很抱歉,暂时无法提供与“AS05708MR-R”相匹配的价格&库存,您可以联系我们找货
