AS01308MR-R
AS01308MR-R
    PUIAUDIO
    SPEAKER 8OHM .2W 86DB 13MM
AS01308MR-R 数据手册
  AS01308MR-R 13mm Speaker 3541 Stop Eight Road • Dayton, Ohio 45414 Product Overview  • 13mm diameter speaker with Neodymium magnet for 86 dB sensi vity • 0.2W con nuous, 0.4W maximum power handling and 8Ω impedance • Mylar cone with pleated surround for wide frequency response Frequency Response (0.2W @ 0.1 meter) PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15.   AS01308MR-R 13mm Speaker Mechanical and Environment Testing Test Description Test Condition High Temperature 55°C with random humidity for 96 hours Packaging Information Low Temperature -20°C with random humidity for 96 hours 40°C with 90% to 95% relative humidity for 96 Humidity hours 1.5 mm movement modulated at 10 to 55 Hz for Vibration 2 hours 75 cm free fall onto 40 mm thick board, 10 cyDrop Test cles -20°C to 55°C, 5 cycles (refer to Temperature Temperature Cycle Test Cycle Test Graph) After tests, speaker shall rest for 1 hours. SPL shall not deviate ±3 dB from pre-test measurement. Temperature Cycle Test Graph Frequency Response Measurement Setup PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15. SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 0.2W/0.1M (AT 1.5, 2.0, 2.5, 3.0 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 0.2 0.4 8 ± 15% W W OHM 86 ± 3 dBA 10% 1,050 ± 20% 1,050 ~ 20,000 METAL MYLAR Nd-Fe-B -20 ~ +55 0.7 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED TOLERANCES AND ROHS STATUS 8/4/2005 10/30/2008 10/9/2013 B.R. M.L. ©2003, Projects Unlimited Inc. Hz Hz - 2B0.2 °C grams P13B0.2 1B0.2 P9B0.2 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE ±0.5 AND ANGLES ARE ±3°. SIZE A3 AS01308MR-R.idw Designed by Date Checked by Date Approved by J.A.F. 8/4/2005 B.R. 8/4/2005 E.P. Date Drawn Date 8/4/2005 10/30/2008 AS01308MR-R Speaker Edition Sheet - 1/1
AS01308MR-R 价格&库存
很抱歉,暂时无法提供与“AS01308MR-R”相匹配的价格&库存,您可以联系我们找货
