AS05008MS-LW152-R
AS05008MS-LW152-R
    PUIAUDIO
    SPEAKER8OHM1.5W85DB
AS05008MS-LW152-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/1M (AT 1.0, 1.2, 1.5, 2.0 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 1.5 3 8 15% W W OHM 85 3 5% 800 20% 800 ~ 7,000 METAL MYLAR NdFeB -20 ~ +60 15.3 50.5 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE - RELEASED FROM ENGINEERING 02/112014 APPROVED 2003, Projects Unlimited Inc. dBA Hz Hz C grams 0.4 152 15 2 RED (+) 50.5 0.4 UL1007 AWG #26 18 0.3 BLACK (-) 57 4 0.3 0.3 (4) 2.3 0.3 12 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS05008MS-LW152-R.idw Designed by Date Checked by Date Approved by J.D. 2/11/2014 M.L. 2/11/2014 B.R. Date Drawn Date 2/11/2014 2/11/2014 AS05008MS-LW152-R Speaker Edition Sheet - 1/1
AS05008MS-LW152-R 价格&库存
很抱歉,暂时无法提供与“AS05008MS-LW152-R”相匹配的价格&库存,您可以联系我们找货
