AS07004PO-R
AS07004PO-R
    PUIAUDIO
    4 Ohm Magnetic Speaker 2W 100Hz ~ 20kHz Top Oval, Rectangular Frame 86dB
AS07004PO-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 0.6, 0.8, 1.0, 1.2 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 2 5 4 15% W W OHM 86 3 5% 300 70 100 ~ 20,000 METAL PAPER Nd-Fe-B -20 ~ +60 35 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED FLANGE HEIGHT DIMENSION REVISED SPL TEST PARAMETERS 4/12/2006 10/9/2006 8/16/2011 3/12/2015 B.R. C.W. M.L. 2003, Projects Unlimited Inc. dBA Hz Hz - 30.5 23 23 0.3 2 C grams 3.3 1 0.3 0.2 (4) 22 70 63 12 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS07004PO-R.idw Designed by Date Checked by Date Approved by B.R. 4/11/2006 B.R. 4/11/2006 E.P. Date Drawn Date 4/11/2006 10/9/2008 AS07004PO-R Speaker Edition Sheet - 1/1
AS07004PO-R 价格&库存
很抱歉,暂时无法提供与“AS07004PO-R”相匹配的价格&库存,您可以联系我们找货
AS07004PO-R
  • 1+48.624651+6.29034
  • 10+37.1912010+4.81125
  • 25+33.5867025+4.34496
  • 50+31.1464150+4.02927
  • 100+28.92310100+3.74165
  • 250+26.27619250+3.39923
  • 500+24.47198500+3.16583
  • 1000+22.819521000+2.95206
库存:163
