SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
OUTPUT SPL @ 1W/0.5M
(AT 0.8, 1.0, 1.2, 1.5 kHz)
DISTORTION (MAX.)
RESONANT FREQUENCY
FREQUENCY RANGE
HOUSING MATERIAL
CONE MATERIAL
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
VALUES
UNITS
3
5
8 15%
W
W
OHM
86
3
5%
250 70
100 ~ 20,000
METAL
PAPER
Nd-Fe-B
-20 ~ +60
38
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
RELEASED FROM ENGINEERING
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
REVISED RESONANT FREQUENCY
5/15/2006
10/9/2008
4/27/2012
B.R.
B.R.
2003, Projects Unlimited Inc.
dBA
Hz
Hz
C
grams
41
25
33.3
2.8
3.7
1
0.3
0.3 (4)
71
22
63.1
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
AS07108PO-R.idw
Designed by
Date
Checked by
Date
Approved by
J.D.
5/15/2006
E.P.
5/15/2006
B.R.
Date
Drawn Date
5/15/2006 10/9/2008
AS07108PO-R
Speaker
Edition
Sheet
1/1
很抱歉,暂时无法提供与“AS07108PO-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+33.87622
- 10+30.50213
- 100+28.09654
- 500+26.08667
- 1000+21.14009
