SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
AVG. SPL 1W/0.1M ON 4MM
THICK PLA PANEL
(AT 0.5, 1.0, 2.0, 5.0 kHz)
RESONANT FREQUENCY
FREQUENCY RANGE
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
R16.5
VALUES
UNITS
3
5
8 15%
W
W
OHM
85
dBA
550 20%
Fo~ 10,500
NdFeB
-20 ~ +60
30
Hz
Hz
0.3
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
2003, Projects Unlimited Inc.
C
grams
23.9
REVISION HISTORY
LTR
DESCRIPTION
DATE
APPROVED
A
B
RELEASED FROM ENGINEERING
ADDED NOTE 4
ADDED M3 THREAD AND POSITIVE TERMINAL INDICATION
5/18/16
6/27/16
1/16/18
B.R.
M.V.
12.5
0.5
0.2
21.5
0.3
M3 THREAD
2.5MM DEEP
16
41
0.3
0.5
34
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3M
VHB
MOUNTING RING
DOUBLE-SIDED TAPE
POSITIVE (+) TERMINAL
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
4. FOR APPLICATIONS THAT ARE TO BE SUBJECTED TO
EXTERNAL FORCE, SHOCK, OR VIBRATION, PUI AUDIO
RECOMMENDS SOLID MECHANICAL
REINFORCEMENT TO ENSURE RIGID COUPLING BEYOND
THAT PROVIDED BY THE
3M VHB F-9473PC DOUBLE-SIDED TAPE.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE 0.5 AND
ANGLES ARE 3 .
SIZE
A3
ASX03308-R.idw
Designed by
Date
Checked by
Date
Approved by
M.V.
5/18/2016
M.V.
5/18/2016
B.R.
Date
Drawn Date
5/18/2016 5/18/2016
ASX03308-R
Exciter
Edition
Sheet
1/1
很抱歉,暂时无法提供与“ASX03308-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+92.715291+12.00386
