AS04008PO-2-WR-R
AS04008PO-2-WR-R
    PUIAUDIO
    SPEAKER 8OHM 1W 84DB 40X28MM
AS04008PO-2-WR-R 数据手册
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 1.0, 1.2, 1.5, 2.0 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 1 2 8 15% W W OHM 84 3 5% 450 20% 450 ~ 20000 ABS TREATED PAPER Nd-Fe-B -20 ~ +60 13 REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE ADDED NOTE 5 REVISED SPEAKER HEIGHT REVISED OUTPUT 9/18/2006 10/7/2008 8/12/2011 5/5/2015 11/5/2018 B.R. B.R. M.L. M.V. 2003, Projects Unlimited Inc. dBA Hz Hz C grams 11.5 3.2 0.2 28.3 0.2 22.5 0.1 3.1 (4) 4 40 16.5 0.2 1 34 0.1 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. CONE HAS BEEN TREATED FOR WATER RESISTANCE. 5. BASE SPEAKER PUI# AS04008PO-2-R. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS04008PO-2-WR-R.idw Designed by Date Checked by Date Approved by J.D. 9/18/2006 R.W. 9/18/2006 B.R. Date Drawn Date 9/18/2006 10/7/2008 AS04008PO-2-WR-R Speaker Edition Sheet - 1/1
AS04008PO-2-WR-R 价格&库存
很抱歉,暂时无法提供与“AS04008PO-2-WR-R”相匹配的价格&库存,您可以联系我们找货
