ASX03304-R
ASX03304-R
    PUIAUDIO
    EXCITER4OHM3W88DBROUND
ASX03304-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE AVG. SPL 1W/0.1M ON 4MM THICK PLA PANEL (AT 0.5, 1.0, 2.0, 5.0 kHz) RESONANT FREQUENCY FREQUENCY RANGE MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT R16.5 VALUES UNITS 3 5 4 15% W W OHM 88 dBA 550 20% Fo~ 10,500 NdFeB -20 ~ +60 30 Hz Hz - 0.3 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. C grams 23.9 12.5 REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING ADDED NOTE 4 ADDED M3 THREAD AND POSITIVE TERMINAL INDICATION 5/18/16 6/27/16 1/16/18 B.R. M.V. 0.5 0.2 21.5 0.3 M3 THREAD 2.5MM DEEP 16 41 0.3 0.5 34 NOTES: 3M VHB MOUNTING RING DOUBLE-SIDED TAPE 1. ALL DIMENSIONS ARE IN MILLIMETERS. POSITIVE (+) TERMINAL 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. FOR APPLICATIONS THAT ARE TO BE SUBJECTED TO EXTERNAL FORCE, SHOCK, OR VIBRATION, PUI AUDIO RECOMMENDS SOLID MECHANICAL REINFORCEMENT TO ENSURE RIGID COUPLING BEYOND THAT PROVIDED BY THE 3M VHB F-9473PC DOUBLE-SIDED TAPE. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 ASX03304-R.idw Designed by Date Checked by Date Approved by M.V. 5/18/2016 M.V. 5/18/2016 B.R. Date Drawn Date 5/18/2016 5/18/2016 ASX03304-R Exciter Edition Sheet - 1/1
ASX03304-R 价格&库存
很抱歉,暂时无法提供与“ASX03304-R”相匹配的价格&库存,您可以联系我们找货
