AS07108PO-LW152-R
AS07108PO-LW152-R
    PUIAUDIO
    SPEAKER8OHM3W86DB
AS07108PO-LW152-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2021, PUI Audio Inc. Data Sheet AS07108PO-LW152-R Features: • 71mm x 41mm x 25mm oval shape • 8 Ω impedance, 3W rated input power • 152mm (6 in) lead wires Specifications Parameters Rated Input Power Max Input Power Impedance Output SPL at 1W/50cm (At 0.8, 1.0, 1.2, 1.5 kHz) Resonant Frequency Frequency Range THD Frame Material Magnet Material Diaphragm Material Terminal Material Weight Acceptable Soldering Methods Polarity Storage Temperature Operating Temperature Environmental Compliances Values 3 5 8 ± 15% Units Watts Watts Ohms 86 ± 3 250 ± 70 100 ~ 20,000 < 5% Metal NdFeB Paper Lead Wires 38 Hand Solder Cone will move forward with positive (+) DC current applied to positive (red) terminal -30 ~ +70 -20 ~ +60 ROHS/REACH dB Hz Hz UL1571 AWG #26 Grams - www.puiaudio.com °C °C - This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2021, PUI Audio Inc. Measurement Method Typical Frequency Response (Measured at 50cm, 1W) www.puiaudio.com This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2021, PUI Audio Inc. Typical Thiele-Small Parameters (based on Golden Sample, up to 20% variance is normal) Specification Re Le Fs Mms Bl Qms Qes Qts Vas Xmax Value 3.686 0.1108 365.4 1.378 Description DC resistance Inductance @ 10 kHz Resonant Frequency Moving Mass Magnet Force Factor Mechanical Q-factor Electrical Q-factor Total Q-factor Equivalent Air Volume of Suspension One-Way Voice Coil Travel 5.807 8.232 3.405 0.1092 Reliability Testing Type of Test Test Specifications Keep 96 hours at +70℃±3℃ and leave 3 hours in normal temperature and then check High Temperature Test Keep 96 hours at -30℃±3℃ and leave 3 hours in normal temperature and then check Low Temperature Test Keep 96 hours at + 40℃±3℃ relative humidity 95% and leave 3 hours in normal temperature and then checked. Humidity Test Low temperature: -30℃±3℃, temperature:+70℃±3℃, cycle: 1 Temperature Cycle Testing hour/cycle each, and then keep 5 cycles in a room. 10~55~10Hz sin-wave sweep 15min. 5G(constant) Vibration Test X,Y, Z 3 direction. 2 hours each, total 6 hours. Max Power Test Max power 1 min on – 2 min off 10 cycles. Free drop from 100cm height to a board of 20mm thick x,y, z 6 Drop Test direction. 1 times each, total 6 times Load Test Rated Power white noise is applied for 96 hours After tests, part SPL shall be within ±3dB. www.puiaudio.com This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2021, PUI Audio Inc. Dimensions (Red Wire +) BLACK GLUE BLACK RED www.puiaudio.com This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2021, PUI Audio Inc. Packaging 井字包装纸盒 一盒100只,一孔一只 一箱2盒,一箱200只 盖板 透明胶带 透明胶带 纸箱 透明胶带 MODEL: QTY: N.W: G.W: SIZE: LOT NO 封箱带 www.puiaudio.com 200PCS kg kg 50.5¡ Á 33¡ Á 17cm This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2021, PUI Audio Inc. Revision A B Note: 1. 2. Specifications Revisions Description RELEASED FROM ENGINEERING Change wire AWG from 28 to 26, packaging adjusted for individual pocket trays Unless otherwise specified: A. All dimensions are in millimeters. B. Default tolerances are ±0.5mm and angles are ±3°. Specifications subject to change or withdrawal without notice. www.puiaudio.com Date 2/20/2014 4/7/2022
AS07108PO-LW152-R 价格&库存
很抱歉,暂时无法提供与“AS07108PO-LW152-R”相匹配的价格&库存,您可以联系我们找货
