AS06608MR-LW152-R
AS06608MR-LW152-R
    PUIAUDIO
    SPEAKER 8OHM .5W 84DB
AS06608MR-LW152-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/1M (AT 0.6, 0.8, 1.0, 1.2 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 0.5 1.0 8 W W OHM 84 ± 3 dBA 5% 380 ± 20% 380 ~ 7,500 - METAL MYLAR NdFeB -20 ~ +60 18 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION - DATE RELEASED FORM ENGINEERING 02/12/2014 APPROVED C.R. ©2003, Projects Unlimited Inc. PRELIMINARY Hz Hz °C grams 12.3 2.2 0.3 66 152 15 2 RED (+) UL1007 AWG #26 BLACK (-) 17.25 0.3 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE ±0.5 AND ANGLES ARE ±3°. SIZE A3 AS06608MR-LW152-R.idw Designed by Date Checked by Date Approved by J.D. 2/12/2014 M.L. 2/12/2014 B.R. Date Drawn Date 2/12/2014 2/12/2014 AS06608MR-LW152-R Speaker Edition Sheet - 1/1
AS06608MR-LW152-R 价格&库存
很抱歉,暂时无法提供与“AS06608MR-LW152-R”相匹配的价格&库存,您可以联系我们找货
AS06608MR-LW152-R
  • 2880+27.016842880+3.48765
