AS07108PO-LW152-WR-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission
of PUI Audio Inc. is prohibited.
©2021, PUI Audio Inc.
Data Sheet
Features:
• 71mm x 41mm x 25mm oval shape
• 8 Ω impedance, 3W rated input power
• Water resistant coating
• 152mm (6 in) lead wires
Specifications
Parameters
Rated Input Power
Max Input Power
Impedance
Output SPL at 1W/50cm
(At 0.8, 1.0, 1.2, 1.5 kHz)
Resonant Frequency
Frequency Range
THD
Frame Material
Magnet Material
Diaphragm Material
Terminal Material
Weight
Acceptable Soldering Methods
Polarity
Storage Temperature
Operating Temperature
Environmental Compliances
Values
3
5
8 ± 15%
Units
Watts
Watts
Ohms
86 ± 3
250 ± 70
100 ~ 20,000
< 5%
Metal
NdFeB
Treated Paper
Lead Wires
38
Hand Solder
Cone will move forward with
positive (+) DC current applied
to positive (red) terminal
-30 ~ +70
-20 ~ +60
ROHS/REACH
dB
Hz
Hz
UL1571 AWG #26
Grams
www.puiaudio.com
°C
°C
Measurement Method
Typical Frequency Response (Measured at 50cm, 1W)
www.puiaudio.com
Typical Thiele-Small Parameters (based on Golden Sample, up to 20% variance is normal)
Specification
Re
Le
Fs
Mms
Bl
Qms
Qes
Qts
Vas
Xmax
Value
3.686
0.1108
365.4
1.378
Description
DC resistance
Inductance @ 10 kHz
Resonant Frequency
Moving Mass
Magnet Force Factor
Mechanical Q-factor
Electrical Q-factor
Total Q-factor
Equivalent Air Volume of Suspension
One-Way Voice Coil Travel
5.807
8.232
3.405
0.1092
Reliability Testing
Type of Test
Test Specifications
Keep 96 hours at +70℃±3℃ and leave 3 hours in normal temperature
and then check
High Temperature Test
Keep 96 hours at -30℃±3℃ and leave 3 hours in normal temperature
and then check
Low Temperature Test
Keep 96 hours at + 40℃±3℃ relative humidity 95% and leave 3
hours in normal temperature and then checked.
Humidity Test
Low temperature: -30℃±3℃, temperature:+70℃±3℃, cycle: 1
Temperature Cycle Testing
hour/cycle each, and then keep 5 cycles in a room.
10~55~10Hz sin-wave sweep 15min. 5G(constant)
Vibration Test
X,Y, Z 3 direction. 2 hours each, total 6 hours.
Max Power Test
Max power 1 min on – 2 min off 10 cycles.
Free drop from 100cm height to a board of 20mm thick x,y, z 6
Drop Test
direction. 1 times each, total 6 times
Load Test
Rated Power white noise is applied for 96 hours
After tests, part SPL shall be within ±3dB.
www.puiaudio.com
Dimensions (Red Wire +)
BLACK GLUE
BLACK
RED
www.puiaudio.com
Packaging
井字包装纸盒
一盒100只,一孔一只
一箱2盒,一箱200只
盖板
透明胶带
透明胶带
纸箱
透明胶带
MODEL:
QTY:
N.W:
G.W:
SIZE:
LOT NO
封箱带
www.puiaudio.com
200PCS
kg
kg
50.5¡ Á
33¡ Á
17cm
Revision
A
B
Note:
1.
2.
3.
Specifications Revisions
Description
RELEASED FROM ENGINEERING
Change wire AWG from 28 to 26, packaging adjusted for individual pocket trays
Unless otherwise specified:
A. All dimensions are in millimeters.
B. Default tolerances are ±0.5mm and angles are ±3°.
Specifications subject to change or withdrawal without notice.
Cone has been treated for water resistance.
www.puiaudio.com
Date
2/14/2014
4/7/2022
AS07108PO-LW152-WR-R 价格&库存
很抱歉,暂时无法提供与“AS07108PO-LW152-WR-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+56.583941+7.33436
- 10+43.3500710+5.61900
- 25+39.1709025+5.07730
- 50+36.3392550+4.71026
- 200+31.39475200+4.06936
- 400+29.23630400+3.78958
- 600+28.05927600+3.63702
- 1000+26.701821000+3.46107
