Driver Specification Sheet
Model No::
HPD-40N16PET00-32
1
Rev:
Product Line: Tymphany
Last Update: 2018-07-11 19:57:16
Product Description
HPD headphone, 40 mm, plastic diaphragm, NdFeB motor, no
faceplate, 32 ohm
Mechanical Drawing
Specifications
DC Resistance
Minimum Impedance
Voice Coil Inductance
Resonant Frequency
Mechanical Q Factor
Electrical Q Factor
Total Q Factor
Ratio Fs/Qts
Half Space Sensitivity @2.83V
Half Space Sensitivity @1W/1M
Gap Height
Maximum Linear Excursion
Ferrofluid Type
Driver Mass
Revc
Zmin
Le
Fs
Qms
Qes
Qts
F
db@2.83V/1M
db@1W/1M
Gh
Xmax
FF
Kg
Ohms
Ohms
mH
Hz
32.8
33.53
2.71
5.0%
7.5%
15%
1.01
Fs/Qts
dB
dB
mm
mm
0.74
110.99
74.18
80.4
1
0.8
+/- 1.0db
+/- 1.0db
Energy Bandwidth Product
Moving Mass
Suspension Compliance
Effective Cone diameter
Effective Piston Area
Effective Volume
Motor Force Factor
Motor Efficiency Factor
Voice coil former Material
Voice coil inner diameter
Rated Noise Power
Test Spectrum Bandwidth
Driver Size
0.01
Frequency and Impedance Response
Tymphany HK LTD
Address : Room 1307-8 Dominion Centre, 43-59 Queens Rd East, Wanchai, Hong Kong
E-mail: sales@tymphany.com
EBP
Mms
Cms
D
Sd
Vas
BL
ß
VCfm
VCd
P
20Hz~20KHz
Inch
(1/Qes)*fs
g
um/N
cm
cm^2
L
Tm
(T*M^2)/Ohms
mm
W
1.5 in
0.3
11.7
3.56
10
1.64
2.42
0.2
Nil
16.36
0.01
很抱歉,暂时无法提供与“HPD-40N16PET00-32”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+61.110471+7.92904
- 5+58.033725+7.52983
- 50+54.9767150+7.13319
- 100+51.92214100+6.73686
- 250+48.86774250+6.34055
