TC6FC00-04
TC6FC00-04
    PEERLESS(PEERLESS扬声器)
    SPEAKER 4OHM 15W TOP PORT 83.2DB
TC6FC00-04 数据手册
Driver Specification Sheet Model No: TC6FC00-04 1 Rev: Product Line: Tymphany Last Update: 2015-08-27 18:51:30 Product Description This TC family 2 inch 4 ohm full-range driver,with neodymium magnet, paper cone and rubber surround, and steel basket, is designed to be a cost-effective high performance full range driver. The cone utilizes Tymphany-patented PentaCut NRSC cone technology to help dampen and control cone resonances, optimizing the listening experience. The motor contains a copper cap to lower inductance and distortion. The product was designed with portable and other compact applications in mind. Mechanical Drawing Specifications DC Resistance Minimum Impedance Voice Coil Inductance Resonant Frequency Mechanical Q Factor Electrical Q Factor Total Q Factor Ratio Fs/Qts Half Space Sensitivity @2.83V Half Space Sensitivity @1W/1M Gap Height Maximum Linear Excursion Ferrofluid Type Driver Mass Revc Zmin Le Fs Qms Qes Qts F db@2.83V/1M db@1W/1M Gh Xmax FF Kg Ohms Ohms mH Hz 3.43 3.89 0.03 186.8 3.29 5.0% 7.5% 15% 1 Fs/Qts dB dB mm mm 0.77 243.87 86.34 83.2 3 1 +/- 1.0db +/- 1.0db Energy Bandwidth Product Moving Mass Suspension Compliance Effective Cone diameter Effective Piston Area Effective Volume Motor Force Factor Motor Efficiency Factor Voice coil former Material Voice coil inner diameter Rated Noise Power Test Spectrum Bandwidth Driver Size 0.08 Frequency and Impedance Response Tymphany HK LTD Address : Room 1307-8 Dominion Centre, 43-59 Queens Rd East, Wanchai, Hong Kong E-mail: sales@tymphany.com EBP Mms Cms D Sd Vas BL ß VCfm VCd P 150Hz - 20kHz Inch (1/Qes)*fs g um/N cm cm^2 L Tm (T*M^2)/Ohms mm W 2 in 1.1 641 4.4 15.2 0.21 2.14 1.3 ASV 19.32 15
TC6FC00-04 价格&库存
很抱歉,暂时无法提供与“TC6FC00-04”相匹配的价格&库存,您可以联系我们找货
