ASX07008-WP-R
ASX07008-WP-R
    PUIAUDIO
    EXCITER8OHM5W82DBROUND
ASX07008-WP-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE AVG. SPL 1W/0.1M ON 4MM THICK PLA PANEL (AT 0.5, 1.0, 2.0, 5.0 kHz) RESONANT FREQUENCY FREQUENCY RANGE MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 5 10 8 15% W W OHM 82 dBA 1200 20% Fo~10,500 NdFeB -20~ +60 115 Hz Hz - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING ADDED NOTE 5 CORRECTED LEAD WIRE LENGTH 5/18/2016 6/27/16 7/13/17 B.R. M.V. C grams 21 70.2 REVISION HISTORY 0.5 46 0.5 0.5 1750 10 24 AWG WIRES MOUNTING PAD 3M VHB DOUBLE-SIDED TAPE 82.75 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. 4. IP67 RATED FOR DUST TIGHT AND WATERPROOF OPERATION TO 1M. 5. FOR APPLICATIONS THAT ARE TO BE SUBJECTED TO EXTERNAL FORCE, SHOCK, OR VIBRATION, PUI AUDIO RECOMMENDS SOLID MECHANICAL REINFORCEMENT TO ENSURE RIGID COUPLING BEYOND THAT PROVIDED BY THE 3M VHB F-9473PC DOUBLE-SIDED TAPE. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 ASX07008-WP-R.idw Designed by Date Checked by Date Approved by M.V. 5/18/2016 M.V. 5/18/2016 B.R. Date Drawn Date 5/18/2016 5/18/2016 ASX07008-WP-R Exciter Edition Sheet - 1/1
ASX07008-WP-R 价格&库存
很抱歉,暂时无法提供与“ASX07008-WP-R”相匹配的价格&库存,您可以联系我们找货
ASX07008-WP-R
  • 1+275.864471+35.56425
  • 10+214.1453510+27.60747
  • 25+194.4099225+25.06319
  • 60+177.6233660+22.89908
  • 120+165.59825120+21.34881
  • 300+161.22721300+20.78530
库存:1492
