TC10FG00-04
TC10FG00-04
    PEERLESS(PEERLESS扬声器)
    COMPACTFULL-RANGE,CLOTHSURROU
TC10FG00-04 数据手册
TC10FG00-04 Revision:2 | Date: 2015-1-20 Full Range This TC family 4 inch 4 ohm full-range driver,with ferrite magnet, paper cone and cloth surround, and steel basket, is designed to be a cost-effective high performance full range driver. The product was designed for Pro column speaker application. MECHANICAL 2D DRAWING SPECIFICATIONS DC Resistance Revc Ω 3.29 ±5.0% Moving Mass Mms g 3.1 Minimum Impedance Zmin Ω 4.21 ±7.5% Suspension Compliance Cms um/N 431.8 Voice Coil Inductance Le mH 0.12 – Effective Cone Diameter D cm 4.3 Resonant Frequency fs Hz 136.68 15% Effective Piston Area Sd cm2 54.1 Mechanical Q Factor Qms – 2.01 – Equivalent Volume Vas L 1.78 Electrical Q Factor Qes – 0.76 – Motor Force Factor BL T•m 3.42 Total Q Factor Qts – 0.55 – Motor Efficiency Factor β (T•m2)/Ω 3.6 Ratio fs/Qts – 248.05 – Voice Coil Former Material VCfm – KSV Half Space Sensitivity dB@2.83V/1m dB 92.3 ±1.01 Voice Coil Inner Diameter VCd mm 25.73 Sensitivity 1W/1m dB 89.5 ±1.01 Gap Height Gh mm 4 Rated Noise Power (IEC 268-5 18.1) P W 30 – Maximum Linear Excursion Xmax mm 1.4 12 dB/Oct 120Hz-20kHz – Ferrofluid Type FF – – Transducer Size – – 4 in – Transducer Mass – Kg 0.6 Test Spectrum Bandwidth Energy Bandwidth Product EBP (1/Qes)•fs         FREQUENCY & IMPEDANCE RESPONSE © 2015 Tymphany HK Ltd. | Address: 1307-8 Dominion Centre, 43-59 Queen's Rd. East., Wanchai, Hong Kong | Email: sales@tymphany.com
TC10FG00-04 价格&库存
很抱歉,暂时无法提供与“TC10FG00-04”相匹配的价格&库存,您可以联系我们找货
