AS07108PO-3-R
AS07108PO-3-R
    PUIAUDIO
    SPEAKER 8OHM 3W 86DB 41X71MM
AS07108PO-3-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 0.8, 1.0, 1.2, 1.5 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 3 5 8 15% W W OHM 86 3 5% 250 70 100 ~ 20,000 METAL PAPER NdFeB -20 ~ +60 36 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED RESONANT FREQUENCY TOLERANCE REVISED TO INVENTOR 3-D DRAWING TEMPLATE 7/14/2006 3/13/2007 5/6/2008 R.W. B.R. 2003, Projects Unlimited Inc. dBA Hz Hz - 41 C grams 33.3 23.5 0.3 2.8 0.3 71 19.2 63.1 3.7 0.3 (4) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AS07108PO-3-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 7/14/2006 E.P. 7/14/2006 R.W. 7/14/2006 5/6/2008 AS07108PO-3-R Speaker Edition Sheet - 1/1
AS07108PO-3-R 价格&库存
很抱歉,暂时无法提供与“AS07108PO-3-R”相匹配的价格&库存,您可以联系我们找货
