ADS02008MR-R
20mm Speaker
3541 Stop Eight Road • Dayton, Ohio 45414
Product Overview
• 20mm diameter speaker with Neodymium magnet for 86 dB sensi vity
• 0.08W con nuous, 0.2W maximum power handling and 8Ω impedance
• Silver polyester cone with pleated surround for great vocal reproduc on
Frequency Response (0.08W @ 0.1 meter)
PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 3/15.
ADS02008MR-R
20mm Speaker
Mechanical and Environment Testing
Test Description
Test Condition
High Temperature
55°C with random humidity for 96 hours
Low Temperature
-20°C with random humidity for 96 hours
40°C with 90% to 95% relative humidity for 96
hours
1.5 mm movement modulated at 10 to 55 Hz for
2 hours
Humidity
Vibration
Drop Test
Packaging Information
75 cm free fall onto 40 mm thick board, 10 cy-
-20°C to 55°C, 5 cycles (refer to Temperature
Cycle Test Graph)
After tests, speaker shall rest for 1 hours. SPL shall not deviate ±3 dB from pre-test measurement.
Temperature Cycle Test
Temperature Cycle Test Graph
SPECIFICATIONS
PARAMETERS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
OUTPUT SPL @ 0.08W/0.1M
(AT 1.0, 1.2, 1.5, 2.0 kHz)
DISTORTION (MAX.)
RESONANT FREQUENCY
FREQUENCY RANGE
HOUSING MATERIAL
CONE MATERIAL
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
VALUES
UNITS
0.08
0.2
8 ± 15%
W
W
OHM
86 ± 3
dBA
5%
750 ± 20%
750 ~ 5,000
ABS
SILVER POLYESTER
Nd-Fe-B
-20 ~ +55
2.3
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
©2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
A
B
DESCRIPTION
DATE
APPROVED
RELEASED FROM ENGINEERING
ADDED ROHS NOTE #3
REVISED TO INVENTOR 3-D DRAWING TEMPLATE
9/21/2005
11/02/2005
10/15/2008
B.R.
B.R.
Hz
Hz
°C
grams
4
3
n19.9
n9.4
SILVER POLYESTER CONE
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2002/95/EC COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE ±0.5 AND
ANGLES ARE ±3°.
SIZE
A3
ADS02008MR-R.idw
Designed by
Date
Checked by
Date
Approved by
J.A.F.
9/21/2005
B.R.
9/21/2005
E.P.
Date
Drawn Date
9/21/2005 10/15/2008
ADS02008MR-R
Speaker
Edition
Sheet
1/1
很抱歉,暂时无法提供与“ADS02008MR-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+32.186001+4.09930
- 10+24.5827010+3.13090
- 25+22.1920025+2.82640
- 50+18.1804050+2.31550
- 80+16.9910080+2.16400
- 240+16.12800240+2.05410
