SPECIFICATIONS
PARAMETERS
VALUES
UNITS
RATED INPUT POWER
MAX INPUT POWER
IMPEDANCE
OUTPUT SPL @ 2.83V/1M
RESONANT FREQUENCY
FREQUENCY RANGE
10
15
8± 15%
82 ± 3
90 ± 20%
90 ~ 15,000
STAMPED
STEEL
ALUMINUM
FERRITE
-20~ +60
360
W
W
OHM
dBA
Hz
Hz
FRAME MATERIAL
CONE MATERIAL
MAGNET MATERIAL
OPERATING TEMPERATURE
WEIGHT
THIS DOCUMENT CONTAINS DATA PROPRIETARY TO
PROJECTS UNLIMITED, INC. ANY USE OR
REPRODUCTION, IN ANY FORM, WITHOUT PRIOR
WRITTEN PERMISSION OF PROJECTS UNLIMITED,
INC. IS PROHIBITED.
©2003, Projects Unlimited Inc.
REVISION HISTORY
LTR
DESCRIPTION
DATE
RELEASED FROM ENGINEERING
7/27/2016
APPROVED
°C
grams
5
P4 (X4)
23
70
15
P77
P92
P60
42
2.6
P55.9
83
NOTES:
1. ALL DIMENSIONS ARE IN MILLIMETERS.
2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL
WITHOUT NOTICE.
3. THIS PART IS RoHS 2011/65/EU COMPLIANT.
UNLESS OTHERWISE
SPECIFIED:
DIMENSIONS ARE IN
MILLIMETERS,
TOLERANCES
ARE ±0.5 AND
ANGLES ARE ±3°.
SIZE
A3
AS09208AR-R.idw
Designed by
Date
Checked by
Date
Approved by
M.V.
7/27/2016
B.R.
7/27/2016
B.R.
Date
Drawn Date
7/27/2016 7/27/2016
AS09208AR-R
Speaker
Edition
Sheet
1/1
p
• Designed for high fidelity full range response
• Purpose-built to work in a wide range of enclosures
• Reinforced mounting flange with integrated gasket
• Vented pole piece improves "chuffing", power compression, and voice coil cooling
• Carefully selected components for maximum reliability and weather resistance
UNLESS OTHERWISE SPECIFIED:
ALL PURCHASES ARE SUBJECT TO THE PUI AUDIO
TERMS AND CONDITIONS SALE FOUND AT
http://www.puiaudio.com/pdf/terms_conditions.pdf
(paper copy available upon request).
DIMENSIONS ARE IN MILLIMETERS,TOLERANCES ARE
±0.5 AND ANGLES ARE ±3°.
很抱歉,暂时无法提供与“AS09208AR-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+237.933511+30.93059
