ASE06008MR-LW150-R
ASE06008MR-LW150-R
    PUIAUDIO
    8 Ohm Magnetic Speaker 2W 400Hz ~ 20kHz Top Rectangular 82dB
ASE06008MR-LW150-R 数据手册
  ASE06008MR-LW150-R 60mm Enclosed Speaker 3541 Stop Eight Road • Dayton, Ohio 45414 Product Overview  • 60 x 30mm speaker with 150mm lead wires for instant integra on • 3W con nuous, 4 maximum power handling and 8Ω impedance • Rugged ABS enclosure designed for op mum sound Frequency Response (1W @ 0.5 meters) PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15.   ASE06008MR-LW150-R 60mm Enclosed Speaker Mechanical and Environment Testing Temperature Cycle Test Graph Test Description Test Condition High Temperature 60°C ±2°C with random humidity for 96 hours Low Temperature -25°C ±2°C with random humidity for 96 hours Humidity 40°C ±2°C with 90% to 95% relative humidity for 48 hours Vibration 1.5 mm movement modulated at 10 to 55 Hz for 2 hours Drop Test 75 cm free fall onto concrete floor, 10 cycles Temperature Cycle Test -25°C to 60°C, 4 cycles (refer to Temperature Cycle Test Graph) After tests, speaker shall rest for 1 hours. SPL shall not deviate ±4 dB from pre-test measurement. Frequency Response and SPL Measurement Setup Speaker Parameters Specification ASE06008MR Fo (Hz) 550 Frequency Range 550 ~ 20,000 Impedance (ohm) 8 SPL (dB) @ 1W/0.5m 83 PUI Audio Inc. engages in continuous product improvement. All specifications are subject to change without notice. www.puiaudio.com. Copyright © 2015. Last Revised 4/15. SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 0.8, 1.0, 1.2, 1.5 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 3 4 8 “ 15% W W OHM 83“ 3 dBA 5% 500 “ 20% 400 ~ 20,000 ABS MYLAR RARE EARTH -25 ~ +60 13.7 - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE - RELEASED FROM ENGINEERING 1/23/2014 APPROVED ‹2003, Projects Unlimited Inc. Hz Hz ƒC grams 150 B5 60 B0.2 1 P6.2 2.3 30 B0.2 UL3302 AWG28 8.9 R4.45 2 2 B1 10.3 B0.2 67.8 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE “0.5 AND ANGLES ARE “3ƒ. SIZE A3 ASE06008MR-LW150-R.idw Designed by Date Checked by Date Approved by J.D. 1/22/2014 M.L. 1/22/2014 B.R. Date Drawn Date 1/22/2014 1/22/2014 ASE06008MR-LW150-R Speaker Edition Sheet - 1/1
ASE06008MR-LW150-R 价格&库存
很抱歉,暂时无法提供与“ASE06008MR-LW150-R”相匹配的价格&库存,您可以联系我们找货
ASE06008MR-LW150-R
    • 1+46.53944
    • 10+41.84280
    • 100+38.61451
    • 500+35.79236
    • 1000+29.10668
    库存:20
