APS2513S-T-R
APS2513S-T-R
    PUIAUDIO
    SPEAKER3OHMTOP83DBRECTANGLE
APS2513S-T-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER VOLTAGE RANGE MIN SPL @ 5 Vrms/5 cm (AT 1.5, 2, 2.5, 3 kHz) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 5 3 - 35 Vrms Vp-p 83 dBA 1300 20% 300 ~ 20,000 PCB -20 ~ +70 0.4 Hz Hz - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. LTR DESCRIPTION DATE - RELEASED FROM ENGINEERING ADDED 10K OHM RESISTOR FOR PROTECTION DURING STORAGE REVISED HEIGHT TO INCLUDE SOLDER JOINTS FOR RESISTOR ADDED LABEL FOR DOUBLE-SIDED TAPE ADDED TOLERANCES TO OVERALL THICKNESS AND DIMENSIONED SOLDER PAD SPACING REVISED TRACES ON PIEZO CERAMIC UPDATED ENVIRONMENTAL STANDARDS 10/6/2016 A 2003, Projects Unlimited Inc. B C D E F APPROVED 12/5/2016 M.V. 12/13/2016 12/22/2016 M.V. M.V. 1/16/2017 M.V. 1/2/2018 1/3/2018 M.V. M.V. C grams 1.5 16.6 1.2 REVISION HISTORY 0.3 20 25.2 2.5 0.5 0.63 14.2 2.3 0 2 DOUBLE-SIDED TAPE 8 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU AND REACH EC/1907/2006 COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 APS2513S-T-R.idw Designed by Date Checked by Date Approved by M.V. 10/6/2016 M.V. 10/6/2016 B.R. Date Drawn Date 10/6/2016 10/6/2016 APS2513S-T-R Speaker Edition Sheet - 1/1
APS2513S-T-R 价格&库存
很抱歉,暂时无法提供与“APS2513S-T-R”相匹配的价格&库存,您可以联系我们找货
