XLS-P830452
XLS-P830452
    PEERLESS(PEERLESS扬声器)
    XLSSUBWOOFER10"250MMPAPER
XLS-P830452 数据手册
Driver Specification Sheet Model No:: XLS-P830452 1 Rev: Product Line: Peerless Last Update: 2017-04-25 14:32:09 Product Description This 10 inch 4 ohm member of the XLS product family has all the design features suitable for a high performance subwoofer driver. The motor features a double ferrite magnet motor, supporting high excursion, and aluminium shorting rings and pole extenders, lowering and linearizing the inductance of the overhung voice coil. The nomex cone is vented under the dust cap, to reduce air compression. The suspension system features a low-creep rubber surround, and a nomex spider, ensuring long-term reliability under high power conditions. The product also features a rigid cast aluminium basket. Mechanical Drawing Specifications DC Resistance Minimum Impedance Voice Coil Inductance Resonant Frequency Mechanical Q Factor Electrical Q Factor Total Q Factor Ratio Fs/Qts Half Space Sensitivity @2.83V Half Space Sensitivity @1W/1M Gap Height Maximum Linear Excursion Ferrofluid Type Driver Mass Revc Zmin Le Fs Qms Qes Qts F db@2.83V/1M db@1W/1M Gh Xmax FF Kg Ohms Ohms mH Hz 3.5 5.38 0.97 22.6 3.67 5.0% 7.5% 15% 0.24 Fs/Qts dB dB mm mm 0.22 101.78 87.64 85.9 8 12.5 +/- 1.0db +/- 1.0db Energy Bandwidth Product Moving Mass Suspension Compliance Effective Cone diameter Effective Piston Area Effective Volume Motor Force Factor Motor Efficiency Factor Voice coil former Material Voice coil inner diameter Rated Noise Power Test Spectrum Bandwidth Driver Size 5.91 Frequency and Impedance Response Tymphany HK LTD Address : Room 1307-8 Dominion Centre, 43-59 Queens Rd East, Wanchai, Hong Kong E-mail: sales@tymphany.com EBP Mms Cms D Sd Vas BL ß VCfm VCd P 20Hz-2KHz Inch (1/Qes)*fs g um/N cm cm^2 L Tm (T*M^2)/Ohms mm W 10 in 143.1 346.6 21.1 349.7 59.52 17.34 85.9 BASV 51.32 150
XLS-P830452 价格&库存
很抱歉,暂时无法提供与“XLS-P830452”相匹配的价格&库存,您可以联系我们找货
