AS05008PR-2-R
AS05008PR-2-R
    PUIAUDIO
    SPEAKER 8OHM .2W 90DB 50MM
AS05008PR-2-R 数据手册
SPECIFICATIONS PARAMETERS RATED INPUT POWER MAX INPUT POWER IMPEDANCE OUTPUT SPL @ 1W/0.5M (AT 0.8, 1.0, 1.2, 1.5 kHz) DISTORTION (MAX.) RESONANT FREQUENCY FREQUENCY RANGE HOUSING MATERIAL CONE MATERIAL MAGNET MATERIAL OPERATING TEMPERATURE WEIGHT VALUES UNITS 0.2 0.4 8 ± 15% W W OHM 90 ± 3 dBA 5% 550 ± 20% 550 ~ 4500 METAL PAPER Nd-Fe-B -20 ~ +60 31 THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR ©2003, Projects Unlimited Inc. A DESCRIPTION DATE APPROVED RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE 5/8/2006 6/18/2008 B.R. Hz Hz - 18.5 °C grams 2.3 50 Ø22 Ø45 0.3 NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE ±0.5 AND ANGLES ARE ±3°. SIZE A3 AS05008PR-2-R.idw Designed by Date Checked by Date Approved by Date Drawn Date J.D. 5/5/2006 E.P. 5/5/2006 B.R. 5/5/2006 6/18/2008 AS05008PR-2-R Speaker Edition Sheet - 1/1
AS05008PR-2-R 价格&库存
很抱歉,暂时无法提供与“AS05008PR-2-R”相匹配的价格&库存,您可以联系我们找货
AS05008PR-2-R
  • 1+41.499781+5.36911
