AB2065B-LW100-R
AB2065B-LW100-R
    PUIAUDIO
    BUZZER ELEMENT PIEZO
AB2065B-LW100-R 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 1kHZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE VALUES UNITS 6,500 500 500 30 14,000 30% BRASS -20 ~ +60 -20 ~ +70 Hz Ohm Vp-p pF - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B RELEASED FROM ENGINEERING REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED STORAGE TEMPERATURE 10/05/2010 12/05/2013 02/12/2020 M.L. M.V. C C A 20 0.2 100 UL1571 AWG #30 5 10 3 0.42 0.1 0.2 0.05 RED (+) BLACK (-) 15 A ( 15 : 1 ) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB2065B-LW100-R.idw Designed by Date Checked by Date Approved by J.D. 10/5/2010 C.W. 10/5/2010 B.R. Date Drawn Date 10/5/2010 10/5/2010 AB2065B-LW100-R Bender Edition Sheet - 1/1
AB2065B-LW100-R 价格&库存
很抱歉,暂时无法提供与“AB2065B-LW100-R”相匹配的价格&库存,您可以联系我们找货
AB2065B-LW100-R
  • 1+19.864691+2.56980
  • 10+15.0687710+1.94938
  • 25+13.5673425+1.75515
  • 50+12.5530850+1.62394
  • 100+11.63168100+1.50474
  • 300+10.33554300+1.33706
  • 500+9.79384500+1.26699
  • 1000+9.114151000+1.17906
  • 5000+7.997305000+1.03458
库存:3859
