AB2022A
AB2022A
    PUIAUDIO
    BUZZER ELEMENT PIEZO 2.2KHZ 20MM
AB2022A 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 1kHZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE VALUES 2,200 300 500 30 80,000 30% ALLOY -20 ~ +60 -20 ~ +70 UNITS Hz Ohm Vp-p pF C C THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D RELEASED FROM ENGINEERING REVISED TO NEW TEMPLATE REVISED SPECIFICATIONS REVISED DIMENSION SIZE AND STYLE REVISED TO INVENTOR 3-D DRAWING TEMPLATE 11/29/2001 9/4/2003 1/9/2004 1/17/2006 8/10/2010 R.W. R.W. B.R. B.R. 2003, Projects Unlimited Inc. A 15 20 0.3 0.1 0.05 0.01 0.1 0.02 A ( 30 : 1 ) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB2022A.idw Designed by Date RABL 11/29/2001 Checked by Date Approved by S.J. Date Drawn Date 11/30/2001 8/10/2010 AB2022A Bender Edition Sheet - 1/1
AB2022A 价格&库存
很抱歉,暂时无法提供与“AB2022A”相匹配的价格&库存,您可以联系我们找货
