AB2040S-LW100-R
AB2040S-LW100-R
    PUIAUDIO
    4kHz Standard Buzzer Element 350 Ohm 30V p-p 0.79" Dia (20mm)
AB2040S-LW100-R 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 100 HZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE VALUES UNITS 4,000 500 350 30 22,000 30% STAINLESS STEEL -20 ~ +60 -20 ~ +70 Hz Ohm Vp-p pF - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 2003, Projects Unlimited Inc. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING REVISED FREQUENCY OF CAPACITANCE SPECIFICATION 11/25/2013 02/12/2020 M.V. C C A 20 0.22 0.05 0.1 0.03 0.1 100 5 5 2 RED (+) BLACK (-) UL1571 AWG# 30 15 0.2 A ( 25 : 1 ) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB2040S-LW100-R.idw Designed by Date Checked by Date Approved by J.D. 11/25/2013 X.X. 11/25/2013 X.X. Date Drawn Date 11/25/2013 11/25/2013 AB2040S-LW100-R Bender Edition Sheet - 1/1
AB2040S-LW100-R 价格&库存
很抱歉,暂时无法提供与“AB2040S-LW100-R”相匹配的价格&库存,您可以联系我们找货
