AB3529BF-LW100-R
AB3529BF-LW100-R
    PUIAUDIO
    BUZZER ELEMENT PIEZO 2.7KHZ 100M
AB3529BF-LW100-R 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 1kHZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE WEIGHT VALUES UNITS 2,900 500 500 30 25,000 30% BRASS -20 ~ +70 -30 ~ +80 3.5 Hz Ohm Vp-p pF - THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PUI AUDIO, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PUI AUDIO, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A RELEASED FROM ENGINEERING UPDATE PLATE THICKNESS DIMENSION 12/06/2013 11/8/2019 ML 2010, PUI AUDIO, Inc. C C g A 35 0.1 100 5 0.63 0.3 5 0.1 0.05 2 BLUE BLACK RED UL1571 AWG #30 24.8 A ( 12 : 1 ) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB3529BF-LW100-R.idw Designed by Date Checked by Date Approved by J.D. 12/6/2013 M.L. 12/6/2013 B.R. Date Drawn Date 12/6/2013 12/6/2013 AB3529BF-LW100-R Bender Edition Sheet - 1/1
AB3529BF-LW100-R 价格&库存
很抱歉,暂时无法提供与“AB3529BF-LW100-R”相匹配的价格&库存,您可以联系我们找货
AB3529BF-LW100-R
  • 1+33.401131+4.32133
