AB2734B
AB2734B
    PUIAUDIO
    BUZZER ELEMENT PIEZO 3.4KHZ 27MM
AB2734B 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 120 HZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE VALUES 3,400 500 1,000 30 13,000 30% BRASS -20 ~ +60 -20 ~ +70 UNITS Hz Ohm Vp-p pF C C THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E RELEASED FROM ENGINEERING REVISED TO NEW TEMPLATE REVISED SPECIFICATIONS REVISED DIMENSIONS SIZE AND STYLE REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED CAPACITANCE FREQUENCY SPECIFICATION 4/11/2002 9/19/2003 1/13/2004 1/24/2006 8/13/2010 2/12/2020 R.W. R.W. B.R. B.R. M.V. 2003, Projects Unlimited Inc. A 27 0.1 0.3 14.6 0.05 0.53 0.5 0.1 A ( 15 : 1 ) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB2734B.idw Designed by Date RABL 4/11/2002 Checked by Date Approved by S.J. Date Drawn Date 4/12/2002 8/13/2010 AB2734B Bender Edition Sheet - 1/1
AB2734B 价格&库存
很抱歉,暂时无法提供与“AB2734B”相匹配的价格&库存,您可以联系我们找货
