AB4113B-LW100-R
AB4113B-LW100-R
    PUIAUDIO
    PIEZO CERAMIC BENDER 30V 1300HZ
AB4113B-LW100-R 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 1kHZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE 29.6 VALUES 1,300 500 200 30 150,000 25% BRASS -20 ~ +60 -20 ~ +70 UNITS Hz Ohm Vp-p pF C C THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. 0.3 REVISION HISTORY LTR DESCRIPTION DATE - RELEASED FROM ENGINEERING 5/20/2013 APPROVED 2003, Projects Unlimited Inc. A 0.4 0.1 29.6 0.03 0.3 41 100 0.05 0.1 5 3 2 A ( 12: 1 ) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2011/65/EU COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB4113B-LW100-R.idw Designed by Date Checked by Date Approved by J.D. 5/20/2013 C.W. 5/21/2013 B.R. Date Drawn Date 5/21/2013 5/20/2013 AB4113B-LW100-R Bender Edition Sheet - 1/1
AB4113B-LW100-R 价格&库存
很抱歉,暂时无法提供与“AB4113B-LW100-R”相匹配的价格&库存,您可以联系我们找货
AB4113B-LW100-R
  • 1+28.454911+3.68141
  • 10+21.6453710+2.80041
  • 25+19.5124325+2.52446
  • 50+18.0689750+2.33771
  • 100+16.75606100+2.16785
  • 300+14.90724300+1.92865
  • 500+14.13396500+1.82861
  • 1000+13.163011000+1.70299
  • 5000+12.054565000+1.55958
库存:133
