AB3528B
AB3528B
    PUIAUDIO
    BUZZER ELEMENT PIEZO 2.8KHZ 35MM
AB3528B 数据手册
SPECIFICATIONS PARAMETERS RESONANT FREQUENCY RESONANT IMPEDANCE (MAX) MAX INPUT VOLTAGE CAPACITANCE @ 100 HZ PLATE MATERIAL OPERATING TEMPERATURE STORAGE TEMPERATURE VALUES 2,800 500 300 30 30,000 30% BRASS -20 ~ +60 -20 ~ +70 UNITS Hz Ohm Vp-p pF C C THIS DOCUMENT CONTAINS DATA PROPRIETARY TO PROJECTS UNLIMITED, INC. ANY USE OR REPRODUCTION, IN ANY FORM, WITHOUT PRIOR WRITTEN PERMISSION OF PROJECTS UNLIMITED, INC. IS PROHIBITED. REVISION HISTORY LTR DESCRIPTION DATE APPROVED A B C D E F RELEASED FROM ENGINEERING REVISED TO NEW TEMPLATE REVISED SPECIFICATIONS REVISED DIMENSIONS REVISED DIMENSION SIZE AND STYLE REVISED TO INVENTOR 3-D DRAWING TEMPLATE REVISED CAPACITANCE FREQUENCY 6/5/2003 9/4/2003 1/15/2004 10/29/2004 1/25/2006 8/13/2010 2/12/2020 R.W. R.W. R.W. B.R. B.R. M.V. 2003, Projects Unlimited Inc. A 35 0.1 25 0.3 0.03 0.56 0.05 A ( 12:1 ) NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. SPECIFICATIONS SUBJECT TO CHANGE OR WITHDRAWL WITHOUT NOTICE. 3. THIS PART IS RoHS 2002/95/EC COMPLIANT. UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MILLIMETERS, TOLERANCES ARE 0.5 AND ANGLES ARE 3 . SIZE A3 AB3528B.idw Designed by Date B.C.I. 6/5/2003 Checked by Date Approved by Date Drawn Date S.J. 6/5/2003 8/13/2010 AB3528B Bender Edition Sheet - 1/1
AB3528B 价格&库存
很抱歉,暂时无法提供与“AB3528B”相匹配的价格&库存,您可以联系我们找货
